Features:
路 Rated to IP20.
路 Status indication.
路 Nominal AC Voltage, 230V.
路 Uc 275V AC can be achieved.
路 Nominal Discharge current: 3kA.
路 Protection class: Type 3, Class III.
路 It can provide protection for equipments.
路 Type 3 SPD according to IEC61643-11 and EN61643-11.
Technology Characteristic锛?/strong>
Application锛?/strong>
路 Designed for installation into electrical installation systems, e.g.: cable ducts and flush-mounted sockets as an additional protection
路 For use in all installation systems of terminal equipment
路 For all installation systems of 230 V terminal equipment
路 For transient current protection
路 For protection of final equipment (TV, PC, etc.).
路 Used for electric power supply networks, telephone networks, and communication and automatic control buses.
Advantage锛?/strong>
路 A compact plastic enclosure, disconnection signals
路 Its small size means that it can be mounted in confined spaces
路 Acoustic fault indication and vision fault indication.
路 35 mm Din rail mounting
路 Have a low discharge capacity.
What is surge锛?/strong>
路 Surges or transients are short duration increases voltage measured between two or more conductors. These potentially harmful voltages can be induced into a building from a direct strike of from secondary effects of lightning which can reach up to 6000 Volts.China 6kA LED Surge Protector
website:http://www.britecelectric.com/led-lightning-protector/6ka-led-surge-protector/
路 Rated to IP20.
Advantage锛?/strong>
