• Please post your message in it's related sections only. Accounts may be blocked or limited if you post in wrong category !
We are growing ! We are Looking for Forum Moderators for this site!
More than 3000 Registered Businesses | Top active VOIP forum | Interested ?..Click to Speak
Works as perfect anti-blocking solution for VOIP.
#1
Optima Saver is an essential bandwidth optimization service for the VoIP traders who need to accommodate more calls in limited internet speed or bandwidth for call termination purposes.
SIM based VOIP gateway and related technology based termination service providers often find themselves facing bandwidth constraint and blockage problems which severely hamper the service quality and uptime. Optima Saver provides fully encrypted service where voice calls are encrypted in Optima Server and then passed through the internet. Also, different levels of security modules are working to make the whole process safe and sound. Optima Saver is the only service in the market which has Customer Controlled Security Tool.
Supported Devices:
•Works with any standard softswitch. Such as VoIPSwitch (VPS), VOS, MVTS, MVTSII, SIppy, Asterisk, PortaOne etc.
•Supports major analog and digital VoIP termination devices like Dinstal, Addpac, GoIP, Cisco, Eurotech, Quintum etc.
Key Features:
•Reduces bandwidth usage for VOIP call termination upto 80%.
•Can work in enterprise environment where it can reduce communication cost by minimizing bandwidth usage while offering better quality of voice and video.
•Works as perfect anti-blocking solution for VOIP.
•Hides original IP address of the termination provider.
•With existing bandwidth upto 5 times more calls can be terminated than normal.
•Supports major audio codecs like G723.1, G729, AMR, GSM, G711 etc in pass through mode.
•Works with all major SIP termination end points like Quintum, Addpac, Dinstar, GoIP, Cisco, Eurotech gateways etc.
•Users can use Optima from all kinds of removable storage like USB HDD, USB flash drive etc.
•Full featured web based billing platform is integrated. Users can view CDR, manage capacity and end points.They can add, edit and delete termination and origination end points.
•Compatible with different kinds of internet networks like broadband, WiFi,WiMAX, 3G, 4G etc.
•Easy to use web based control panel with lots of useful features.
•Compatible with public, private, static, DHCP networks.
•Works with both real IP and local IP addresses.
•Works from behind the NAT and firewall.
•Reduces Post Dialing Delay (PDD).
Contact us to advertise on this website!
