Simple way to Mount CD or DVD on linux
Discussion in 'VoIP Knowledge Base' started by karthikkondapaneni, Jul 7, 2017.
  1. First check what are the devices available with the command blkid
    #blkid
    /dev/sr0: LABEL="RHEL_5.9 x86_64" TYPE="iso9660"
    from the list we can assume that there is disk labeled RHEL_5.9 x86_64 in optical drive .
    Now we can mount it in /mnt/cdrom or /media/cdrom directory . If there is no directory you can create it .
    # mkdir /media/cdrom
    #mount -t iso9660 /dev/sr0 /media/cdrom
    to unmount use umount command
    #umount /media/cdrom
    To eject CD or DVD in linux you can use eject comamnd
    # eject
    eject -t will close the tray and eject -T will close or open the tray
Share This Page
